Hi!
I have problems inserting SSL client x509 certificate information into HTTP::header’s when client SSL certificate is required only for certain parts of an application (https virtual server).
The problem is, that in HTTP_REQUEST event we check if client SSL certificate is needed…
if { $gotcert == 0 and [HTTP::uri] startswith “/needcert”') {
When this condition is true, we have not yet received SSL client cert but we sure would like to get one, thus we have to set ‘SSL::cert mode require’ and ask for ‘SSL::renegotiate’ …
Now CLIENTSSL_HANDSHAKE event is re-evaluated and client supplies it’s client x509 certificate (or does not) and we either:
- reject the request when no SSL::cert is supplied but $needcert==1
or
- accept the certificate and call HTTP::release.
As a result of all this, when ‘/needcert’ URL is requested (for the VERY FIRST TIME by the client) [SSL::cert count] == 0 when HTTP_REQUEST event is evaluated and there is no X509 certificate to be used in those ‘HTTP::header insert [X509::.. ]’ commands (at the end of the HTTP_REQUEST event -- see the iRule below).
But, if the client re-requests the page, the SSL session gets reused
and client certificate is present when HTTP_REQUEST event is evaluated and everything works the way I want..
Is there some way to work-around this problem?
eg. Is it somehow possible to call HTTP::header insert functions in CLIENTSSL_CLIENTCERT or CLIENTSSL_HANDSHAKE events?
Currently i cannot call command 'HTTP::header insert ’ in CLIENTSSL_HANDSHAKE event, but I get a iRule compilation error:
[command is not valid in current event context (CLIENTSSL_HANDSHAKE)] [HTTP::header insert …]
SEE ALSO:
http://devcentral.f5.com/Default.aspx?TabID=29&newsType=ArticleView&articleId=39
--- here is my iRule ---
rule https-needcert {
when CLIENT_ACCEPTED {
set needcert 0;
set gotcert 0;
when CLIENTSSL_HANDSHAKE {
log LOCAL0.warn “cert count=[SSL::cert count] result=[SSL::verify_result]”;
if { [SSL::cert count] == 0 or [SSL::verify_result] != 0 } {
log LOCAL0.warn “Bad cert!”
if { $needcert == 1 } {
reject
log LOCAL0.warn “Good cert! ($needcert)”
set gotcert 1
set crt [SSL::cert 0];
HTTP::header insert “X-ENV-SSL_CLIENT_S_DN” [X509::subject $crt];
HTTP::release
if { $gotcert == 0 and [HTTP::uri] starts_with “/needcert” } {
log LOCAL0.warn “Requiring certificate…”
HTTP::collect
SSL::renegotiate
set needcert 1
log LOCAL0.warn “No cert needed.”
if { [SSL::cert count] > 0 } {
HTTP::header insert “X-ENV-SSL_CLIENT_I_DN” [X509::issuer $crt];
HTTP::header insert “X-ENV-SSL_CLIENT_M_SERIAL” [X509::serial_number $crt];
HTTP::header insert “X-ENV-SSL_CLIENT_V_START” [X509::not_valid_before $crt];
HTTP::header insert “X-ENV-SSL_CLIENT_V_END” [X509::not_valid_after $crt];
HTTP::header insert “X-ENV-SSL_CLIENT_CERTIFICATE” [X509::whole $crt];
