Hello
I have a vs named flane with waf policy and logging profile configured to log all requests. However, I’ve noticed that requests with HTTP 307 redirect responses are not being logged. To investigate, I created an irule to log all requests and responses. These logs appear correctly in the ltm log generated by the iRule, confirming the traffic flow.
What could be the reason for this? It doesn’t seem to be a sporadic issue, as all requests with 307 responses are consistently not logged.
307 redirect is a redirect by browser itself usually due to hsts.
So if 307 is not be sent by the server that’s why you will never be able to log it.
To set response codes, and to appear in the Application Event Logs (ex: 3xx, 4xx, 5xx)
check this and review per your AWAF policies
If t is not sent by server, where are the HTTP 307 logs in ltm log coming from?
Good point, in which irule event do you log them?
HTTP::RESPONSE of course
set is_pelecard1 0
set path1var [HTTP::path]
set host1var [HTTP::host]
set cip1var [IP::client_addr]
if {($path1var contains “pelecard” )} {
set is_pelecard1 1
set uri1var [HTTP::uri]
set vs1var [IP::local_addr]
log local0. "client ip=$cip1var >> vs: $vs1var $host1var$uri1var [IP::client_addr] [IP::remote_addr] [IP::local_addr] "
when HTTP_RESPONSE {
if {(($is_pelecard1 == 1 ) or ($cip1var == “99.99.99.8”))} {
log local0. “HTTP Status = [HTTP::status] [IP::client_addr] [IP::remote_addr] [IP::local_addr] [IP::server_addr]”
LTM log:
May 21 07:41:19 f5_ASM01 info tmm2[10293]: Rule /Common/_Troubleshoot-iRule <HTTP_RESPONSE>: HTTP Status = 307 99.99.99.8 10.20.3.36 51.51.51.50 10.20.3.36
In that case, 307 is definetely coming from server
But ASM is logging only security event logs by default
307 is not considered security event
Have you adjust logging to log all requests?
As I mentioned at the beginning: “logging profile configured to log all requests”
