Hello,
A pair of BIG-IP appliances (running 12.1.2) in active/standby mode installed in two different DCs with the management port connected to management switches (with the management VLAN L2 spread between two DCs).
I need to replace the management switch in both DCs. Is it recommended to put standby unit Offline during the maintenance to prevent failover? Looking at tcpdump I see quite a lot of failover_packet traffic between two units over the management VLAN.
Thank you.
Hi Novice,
Using the „Force Offline“ mode is always a good choice if you perform maintenance task on a given unit. So yes i would use it to make sure the unit stays offline until the work is done…
Cheers, Kai
If you are running viprion or vcmp on viprion then this command may not work for you. You need to configure minimum number of blades to keep one of the box standby
Management port can be used for following features:
- Management through SSH / WebUI
- Out of band access to management with AOM
- Logs / SNMP outbound connections if destinations are in same network as Management port or a specific management route was configured
- failover heartbeat
The most critical service is failover heartbeat. The recommended configuration is to define 2 failover networks :
- one HA network
- Management Network
If your deployment is configured with both networks (
Device Management ›› Devices ›› your device ›› Failover
) and HA plan self IPs are defined with Port Lockdown
Allow Default
or
Allow All
, you can unplug the management port without issue.
