Replace subdomain and remove path
Greetings,
I’m struggling with this :
I would like this : http://www.mysite.org/customfiles/mydoc.htm transformed into this: http://customfiles.mysite.org/mydoc.htm
Of course, there are several files, mydoc.htm is just an example. And the original site www.mysite.org must not be affected.
Note : This URL will be forwarded to a pool so I cannot use redirect.
I’ve written the following iRule:
if { [HTTP::path] starts_with "/customfiles"} {
  HTTP::path [string replace [HTTP::path] 0 12 ""]
  HTTP::header replace Host "customfiles.onprvp.fgov.be"
  pool my_pool
And nothing happens. In the F5 logs we only have a warning message saying the rule already exists on partition Common, but nothing else.
I suspect that the string replace isn’t very happy but a string map gives the same.
What am I doing wrong ? :slightly_smiling_face:
Olivier, by no means an expert but I’d use string range instead e.g.
HTTP::path [string range [HTTP::path] 0 12]
Does this work for you?
N
It may be beneficial to verify that hyperlinks on those pages will continue to point to valid URLs.
I think counting may be the problem :-);
        HTTP::uri [string replace [HTTP::path] 0 11 ""]
        pool my_pool
Hello all,
Thanks very much for your answers.
I have tried your suggestions but unfortunately it does not work :frowning:
I keep on searching and keep you informed of the results.
Olivier
(Sorry for my late answer, just came back from a few days off)
have you run tcpdump to see what wrong is?
e.g.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        http { }
        tcp { }
    rules {
        myrule
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 2
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
  if { [HTTP::path] starts_with "/customfiles/" } {
    HTTP::uri [string map {/customfiles/ /} [HTTP::uri]]
    HTTP::header replace Host "customfiles.mysite.org"
 trace
[root@ve11a:Active:In Sync] config  ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.1(36831) <-> 172.28.24.10(80)
1391521795.0090 (0.0011)  C>S
GET /customfiles/mydoc.htm HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Accept: */*
Host: www.mysite.org
New TCP connection 2: 200.200.200.14(36831) <-> 200.200.200.101(80)
1391521795.0275 (0.0173)  C>S
GET /mydoc.htm HTTP/1.1
Accept: */*
Host: customfiles.mysite.org
and logging;-
        log local0. "Replacing [HTTP::uri] with [string replace [HTTP::path] 0 11 ""]"
        log local0. "Replaced - \[HTTP::uri\] is [HTTP::uri]"
        pool my_pool
