Hello,
I have set up a kubernetes lab cluster and then I implemented the f5 components following the guide under http://clouddocs.f5.com/containers/v1/kubernetes/, everything worked as it should. At the end jt is neccesary to replace the kube-proxy with the f5-asp. I used the manifest f5-kube-proxy-ds.yaml and the kubernetes took it without any problem, a kubectl get ds -n kube-system shows the implemented manifest. My problem is now, that the pods with the f5-asp proxy replacement does not come up:
kube-proxy-hqcmr 0/1 CrashLoopBackOff 171 14h
kube-proxy-sb86d 0/1 CrashLoopBackOff 171 14h
the log entries:
invalid configuration: [unable to read client-cert /var/lib/kubelet/pki/kubelet-client.crt for default-auth due to open /var/lib/kubelet/pki/kubelet-client.crt: no such file or directory, unable to read client-key /var/lib/kubelet/pki/kubelet-client.key for default-auth due to open /var/lib/kubelet/pki/kubelet-client.key: no such file or directory]
has anybody seen this error before? any help is welcome
