Renewing device certificate - safe?
I have an HA pair of Big-Ip 3900’s, and the device certificate has expired (self signed) can I safely renew it without fear of causing any stoppages to the customer facing web applications?
this is version 11.3 so I can make the expiration a 10 year date now…
The device certificate doesn’t relate to your Virtual Servers and the like so no worries there. However, device group trust relies on it quite heavily so I’d recommend any changes you make are out of hours, or factor in the possibility of re-establishing HA device trusts.
Might be helpful to identify which device certificate you’re referring to.
If you’re referring to the device certificate for UI admin page, that would be here:
/config/httpd/conf/ssl.crt
As mentioned, this shouldn’t affect connectivity through the SSL Virtual Servers.
The device trust certificate for HA would be here:
/config/ssl/ssl.crt/dtca.crt
It would be best to take a maintenance window if updating these since you have to break the device trust to update them.
Thanks! better safe than sorry…
Welcome. Just to sharpen this statement a bit:
It would be best to take a maintenance window if updating *the dtca.crt" since you have to break the device trust to update them.
@Kevin.K RE: “Might be helpful to identify which device certificate you’re referring to. If you’re referring to the device certificate for UI admin page, that would be here: /config/httpd/conf/ssl.crt”
Is there documentation about how to change the UI admin page certificate only?
Thanks.
Hi Stuart, Both of these offer the steps. First SOL is probably the easiest, but the second offers a bit more detail:
Kevin
thanks for the info. Those were good docs.
Thanks for the followup note Stuart, that’s great to hear.
