Has anyone ever changed the hostname of an LTM? Is it simply a matter of executing the hostname command and rebooting? I have some GTMs, so I suppose I may need to adjust the authorized_keys2 file to account for a new public key. Is there anything else I should consider?
Hi SMP,
Using the hostname command won’t update the BIG-IP-specific configuration for the hostname. From SOL4802:
For BIG-IP versions 9.4.2 and later:
bigpipe system hostname
Replace with the fully qualified hostname for the BIG-IP system.
For example:
bigpipe system hostname askbig9n1.askf5.com
For BIG-IP versions 9.0 through 9.4.1:
bigpipe db HostName
For example:
bigpipe db HostName askbig9n1.askf5.com
Maybe someone else can comment on any changes you’d need to make for the GTM’s.
Aaron
Does anyone know if changing the hostname has any impact on certificates installed on the box?
Does anyone know if changing the hostname has any impact on certificates installed on the box?is it ltm only? what version is it? what certificate do you mean (e.g. ssl profile certificate, device management certificate)?
In TMSH, You can
modify sys global-settings hostname
