Hey everyone!
We have an application that uses iframe to load another site that´s apm protected, but the default x-frame-options deny blocks this. Anyone have any ideas on how to bypass this (withouth globally disabling this feature)?
I´ve tried several irules at different events to remove the header, but without any progress..
This should do the trick.
when CLIENT_ACCEPTED {
ACCESS::restrict_irule_events disable
when HTTP_RESPONSE_RELEASE {
HTTP::header remove "x-frame-options"
Will give it a try, just have to wait for the user to test again
That´s a negative on that, your irule was almost identical to mine .. except for the first event. But what i added that, the apm policy doesnt fire at all… When i access the vip there is nothing.
The apm policy fires always if it is attached to the vs, unless you add an ACCESS::disable anywhere.
Why ACCESS::restrict_irule_events is required: ACCESS::restrict_irule_events
Yes, we had some other issues.. and they just appeared at the same time. The first part was what i was missing, so this will not be forgotten in the future.
