I am working with a customer that want to put all of their networks that are currently directly connected to the F5, behind another L3 interface. So we are now affectedly rouring to the node, rather than being directly connected to it.
When I try and delete the VLAN it produces the following message.
01070265:3: The VLAN (/Common/VLAN_xx) cannot be deleted because it is in use by a self IP (xx.xx.xx.xx).
I have added a default route, so the node is still reachable, so how do I remove the VLANs from the config
Hi Nitass, Thanks for the reply, I tryed all those things, it is still the same - if I try and force reload, I just get the same error in TMOS I will keep trying and see what I come up with
As long as you have objects that reference a specifically defined subnet, you’re not going to be able to delete the self-IP and consequently the VLAN. As you’ve found, however, you don’t need to delete the VLAN and self-IP to get to these routed nodes. You don’t even really need a default route as long as you have A route. So what you’re probably going to have to do is (perhaps slowly) migrate existing pools to the routed members, and once all of the local stuff is gone, then you can delete the self-IP.
How is it going to use the routing table, when it thinks it is a directly connective network.
I have never had this situation before, so I dont know - It just seems like it wont, because a directly connected network might have priority over a route
You have pool members that are in a different subnet and you have a route to that subnet through either a default or other specific route. If you create a route to another subnet then you should have a VLAN and self-IP in the local subnet (the subnet that exists between the F5 and the router) - so the device knows which physical path to take to get to that network. You could alternately send a route through a specific VLAN, but it certainly doesn’t hurt to have a local self-IP.
i did a bit test (below) but it did not work. so, it seems you have to modify configuration file directly (i.e. bigip_base.conf and bigip.conf) and then force mcpd to reload the configuration.
existing pool
root@ve10(Active)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:http { }
existing connected subnet
root@ve10(Active)(tmos) list net self 200.200.200.16/24
net self 200.200.200.16/24 {
allow-service default
vlan internal
new vlan
root@ve10(Active)(tmos) create net vlan newvlan interfaces add { 1.2 { tagged } }
new selfip
root@ve10(Active)(tmos) create net self 222.222.222.16/24 vlan newvlan allow-service default
new route but error
root@ve10(Active)(tmos) create net route 200.200.200.0/24 gw 222.222.222.254
01070666:3: Static route duplicates Self IP 200.200.200.0 / 255.255.255.0 implied route
delete selfip but error
root@ve10(Active)(tmos) delete net self 200.200.200.16/24
01070605:3: Cannot delete IP 200.200.200.16 because it would leave a pool member (pool foo) unreachable.
existing pool
ltm pool foo {
members {
vlan internal
new vlan
new selfip
new route but error
Change the Subnet Mask on the Self-IP from a /24 to a /32 (255.255.255.255). This will then allow you to delete the Self-IP from the configuration
thanks, it’s nice.
existing configuration
[root@B3600-R66-S40:Active] config b vlan internal list
vlan internal {
tag 423
interfaces tagged 1.1
[root@B3600-R66-S40:Active] config b self 200.200.200.40 list
self 200.200.200.40 {
netmask 255.255.255.0
vlan internal
allow default
[root@B3600-R66-S40:Active] config b pool foo list
pool foo {
members 200.200.200.101:http {}
deleting
[root@B3600-R66-S40:Active] config b self 200.200.200.40 netmask 255.255.255.255
[root@B3600-R66-S40:Active] config b self 200.200.200.40 delete
BIGpipe self IP address query error:
01020036:3: The requested self IP address (200.200.200.40) was not found.
pool foo {
I tried this and I could delete the Self-IP, but the LTM doesn’t seem to be able to communicate to any of the Real Servers which were reachable by the Directly connected Internal VLAN. That subnet is now routed via the External VLAN. Checked the Upstream Routers and the Big-IP’s External and Internal VLANs are directly connected Networks so no routes are needed there. Am I missing anything.
