Hello,
can anybody tell me, if it is possible to remove
a specific monitor from a pool?
The interface “remove_monitor_association” removes
all my monitors.
Thanks in advance
Ian
Hello,
all my monitors.
Thanks in advance
Ian
Looks like you are correct, I don’t see a way to remove a single assocation without removing all of them.
In the mean time, you can use the following logic to emulate this method
1. call get_monitor_associations() to return a list of current assocations.
2. call remove_monitor_association() to remove the associations to the pool.
3. remove the association from the returned list from get_monitor_associations().
4. call set_monitor_association() with the new list.
I look into getting this added in a future release.
-Joe
Thanks Joe,
I’ll try this.
Could you please tell me why I am getting an “500 Internal Server Error” with this code. I think it should be correct.
Thanks in advance
Ian
package SAM::Tool::BigIP::POOL::addPoolMonitor;
use strict;
use warnings;
use SAM::Syntax;
use SAM::System;
use SAM::Tool::Status qw(user);
use SOAP::Lite;
use MIME::Base64;
use iControlTypeCast;
my $sHost = shift @_;
my $sPort = shift @_;
my $sUID = shift @_;
my $sPWD = shift @_;
my $sPoolName = shift @_;
my $sMonitor = shift @_;
my $sProtocol = “https”;
SOAP::Transport::HTTP::Client::get_basic_credentials($sUID,$sPWD);
sub SOAP::Transport::HTTP::Client::get_basic_credentials
my $uid_ref = shift;
my $pwd_ref = shift;
return “$uid_ref” => “$pwd_ref”;
if ( (“80” eq $sPort) or (“8080” eq $sPort) )
$sProtocol = “http”;
my $PoolCreate = SOAP::Lite
→ uri(‘urn:iControl:LocalLB/Pool’)
→ proxy(“$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi”);
eval { $PoolCreate->transport->http_request->header
‘Authorization’ =>
'Basic ’ . MIME::Base64::encode(“$sUID:$sPWD”, ‘’)
$sPoolName = “TestPoool”;
my $attribute = { type => “MONITOR_RULE_TYPE_SINGLE” , quorum => 0, monitor_templates => “testmonitor” };
my $Monitor = { pool_name => $sPoolName , monitor_rule => $attribute };
---------------- idev -------
my $soapResponse = $PoolCreate->set_monitor_association(
SOAP::Data->name( monitor_associations => [$Monitor] )
&checkResponse($soapResponse);
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring,
“\n”;
exit();
The only thing that sticks out is that the monitor_templates member of the MonitorRule structure is an array and you are passing in a single string. Try changing your code to the following
my $attribute = {
type => "MONITOR_RULE_TYPE_SINGLE" ,
quorum => 0,
monitor_templates => ["testmonitor"] };
-Joe
Thanks a lot Joe, you saved my day.
Ian
