In order to remove the third interface 1.3 from VE, you need to do the following:
1. Go to the standby unit after performing a sync and execute following commands:
cp /var/db/mcpdb.bin /var/opt/
cp /var/db/mcpdb.info /var/opt/
this creates a back up for them. < you can choose any other directory to create a back up to >
**** you can also take a snapshot of the VM so you can restore it as it is before the removal attempt ****
2. Next execute the following command to clear the db:
rm /var/db/mcpdb*
3. After that we need to go to the config directory and remove interface 1.3 using vi editor: (Thanks Harry Le for your help !)
cd /config
vi bigip_base.conf
4. Save changes made in vi editor and confirm that the interface is removed by using command:
less bigip_base.conf
5. Next step is to shutdown the VM and remove Virtual Switch (network adaptor) attached to that interface and then power on VM.
… Bingo your interface 1.3 has been removed from VE F5.
6. Follow the same steps for Active unit, after making it a standby.
