removing authorization header for LDAP
Hi All,
I have looked at some iRule examples that show show to remove the authorization http header but have some hard time making it to work.
Basically, I have http traffic that needs to be authenticated using LDAP. But I want to remove the authorization http header on the server side. When the LDAP authentication is successful, the users are allowed to see the data.
I tried “request header erase” on the http profile but it erases it even before the user gets authenticated.
Also, I found the following irule in the forum but this also erases the authorization information from the header before the authentication.
when HTTP_REQUEST priority 501 {
Remove the Authorization header after the system authorization iRule runs (at priority 500)
if {[HTTP::header exists Authorization]} {
[serverside {HTTP::header remove Authorization}]}
Any ideas?
Meena
I think what you’re looking for is the AUTH_SUCCESS event. You could set a variable in this event, then in the HTTP_RESPONSE event you could use the HTTP::header remove command if the variable is set, showing that an AUTH_SUCCESS event occured. This way you could remove the header on the server side, but only if the login worked.
Sound about right?
Colin
