Remove values of a response header
Hi everybody,
I need to remove the values of a response header. For example:
access-control-allow-headers    ----->  X-Request-UUID, X-Web-Optimize-Response, X-Web-Client-Id, X-Web-City-Id, X-Web-ClientI
I need to remove “X-Web-City-Id” and keep everything as they are.
I couldn`t find a related iRule.
I would appreciate it if somebody could help me with this.
Best,
Ali
Hello Asamadyar.
If the header is located in the Response, you could remove it with next iRule.
when HTTP_RESPONSE
	HTTP::header remove "X-Web-City-Id"
Take into account that you would need a HTTP profile applied.
Many thanks,  @Dario_Garrido
I don`t want to remove the header; I need to remove one value.
header ------------------------------------------- value
x-x-x                                                       t1, t2, t3, t4, t5
And I need to remove, for example, “t3” and keep everything intact in the response header.
I think your code will completely remove the header (x-x-x).
Hello Asamadyar.
Try with this code
when HTTP_RESPONSE {
	if { [HTTP::header "access-control-allow-headers"] ne "" } {
		if { [HTTP::header "access-control-allow-headers"] contains "," }{
			set acheaders [split [HTTP::header "access-control-allow-headers"] ","]
			set output ""
			foreach acheader $acheaders {
				if { $output eq "" } {
					if { !($acheader contains "X-Web-City-Id") } { set output "$acheader" }
					if { !($acheader contains "X-Web-City-Id") } { set output "$output,$acheader" }
			#log local0. "INPUT: [HTTP::header "access-control-allow-headers"]"
			HTTP::header replace "access-control-allow-headers" $output
			#log local0. "OUTPUT: [HTTP::header "access-control-allow-headers"]"
