Remove UDP connection from connection table using iRule
I have the below snippet in an iRule to dynamically create a UDP connection for outbound SIP media:
Pre-establish the UDP connection to allow RTP from Server → Client (and vice versa)
relate_server {
proto 17
clientflow $source_VLAN $destination_RTP $destination_RTP_port $source_inside $source_RTP_port
serverflow $destination_VLAN $source_outside $source_RTP_port $destination_RTP $destination_RTP_port
I see connections on the CLI as expected…but they are all subject to the UDP timeout setting to be removed from the connection table (example of a live call below, hence idle time = 0).
[root@QORA-LTM-SIP01:Active] config tmsh show sys connection cs-client-addr 10.140.14.36
10.140.14.36:5060 10.2.18.155:5060 any6.any any6.any udp 4 (tmm: 0) SIGNALLING
10.140.14.36:49178 68.68.118.85:17608 199.127.147.213:49178 68.68.118.85:17608 udp 0 (tmm: 0) MEDIA/RTP
Is anyone aware of a means to REMOVE this connection entry in the same way that I created it within the iRule? I know to do so on the CLI, but ideally I’d like to tear down the connection in the same iRule that created it…
Thanks in advance!
