I would like to remove the routing domain suffix “%1” in the log file i’m creating.
Here’s a sample of my Irule.
when HTTP_REQUEST { set client_ip [IP::remote_addr] set log_msg “” append log_msg “$client_ip”
The result in the log file is “192.168.1.5%1” but i need to have it without the “%1”. I’m wondering if a regex could do the job inside my Irule but i’m stucked in finding a way. Any help would be appreciated Aurel
Hello guys, Thanks for your reply. Kevin, i actually don’t understand the how to use it from your examples.(sorry about it) I did understand yours nitass, and i forgot to mention something else. I actually need to match string that could be “%[1-9][1-9][1-9]” (in a regex syntax). But this is not working with tcl, the way i tried anyway.
I was showing you performance output using TCLSH from the command line and the time command. It’s probably not likely that you have more than a few defined route domains, all of which you know about in advance, so a literal string map is probably most efficient:
If, however, you truly need something more dynamic, then a regular expression will work. Keep in mind of course that a regular expression is, in general, going to be more CPU-intensive.
% set test1 "10.10.10.10%1"
10.10.10.10%1
% set test123 "10.10.10.10%123"
10.10.10.10%123
% scan $test1 {%[^%%]%%%d} a b
2
% put $a
10.10.10.10
% put $b
1
% scan $test123 {%[^%%]%%%d} a b
2
% put $a
10.10.10.10
% put $b
123
10.10.10.10%1
10.10.10.10%123
2
% put $a
10.10.10.10
% put $b
1
2
% put $a
10.10.10.10
% put $b
123
The scan and regsub commands both work on regular expressions, so both will do a better job of matching a dynamic set of numbers - at the expense of performance. I’m doubtful that you have a large set of dynamic route domain assignments, so given the assumption that 1) it’s a small set, and 2) you already know what those RD values are, an explicit [string map] is probably more efficient. But I want to express that [string map] is an explicit search - you have to know what you’re looking for. In your case, since “223” is the RD number, your syntax would look something like this:
Yes Nitass, this is doing the job fine. That’s seems fine. As Kevin said, it looks that is using regex and then will consume CPU a little more than “tcl native” commands. Am i right ? I’d like (as far as possible) to do this with the fewest impact on performance.
