remove a confirmed IP address from X-Forwarded-For using Irules
How to remove a confirmed IP from X-Forwarded-For such as 1.1.1.1 or 2.2.2.2,thanks a lot!
You can use the “string map” command to remove a known IP from the XFF header.
For example:
 if { [HTTP::header value "X-Forwarded-For"] contains "1.1.1.1" } {
   This will replace the 1.1.1.1 by ""
   set new_xff [string map {1.1.1.1 ""} [HTTP::header value "X-Forwarded-For"] ]
   You can add logs to /var/log/ltm to verify if it works correctly
   log local0. "Old XFF: [HTTP::header value "X-Forwarded-For"]"
   Then you can modify the value and log again to verify the new value
   HTTP::header replace "X-Forwarded-For" $new_xff
   log local0. "New XFF: [HTTP::header value "X-Forwarded-For"]"
Hope it helps
