I am wanting to set up my BIGIP 2000 units to remote log to our syslog server, but only log Notice , Warning and Emergency.
I have found a guide that I will be able to use but I am unsure of the syntax using the tmsh for filtering :
include " filter f_remote_loghost { level(warn,emerg,notice); - This line I am unsure of };
destination d_remote_loghost { tcp(\“10.11.16.253\” port(1468)); udp(\“10.11.16.252\” port(514)); };
log { source(s_syslog_pipe); filter(f_remote_loghost); destination(d_remote_loghost); }; "
can someone please sanity check the above and make sure the syntax is correct to only log warning, emergency and notice.
