I am needing to only send local0.notice messages to a remote syslog server. currently im sending to much local6.info messages. If tried the Gui menu Logs:Configuration:Options and other tmsh commands ive found on Ask F5, but so far no luck. Any suggestions on how to only send local0.notice to the remote syslog.
Try this
tmsh modify /sys syslog include "destination remote {udp(\"10.10.10.10\" port (514));};filter f_notice {level (notice...emerg);};log {source(local);filter(f_notice);destination(remote);};"
Nope, still getting lots to local6.info…the only thing i changed in the script was the IP, unless i should have changed more?
Modified with the filter facility
tmsh modify /sys syslog include "destination remote_server {udp(\"10.10.10.10\" port (514));};filter f_notice {level (debug...emerg);};filter f_local0 {facility (local0);};log {source(local);filter(f_notice);filter(f_local0);destination(remote_server);};"
Verify
tmsh list /sys syslog all-properties
There is a typo earlier
tmsh modify /sys syslog include "destination remote_server {udp(\"10.10.10.10\" port (514));};filter f_notice {level (notice...emerg);};filter f_local0 {facility (local0);};log {source(local);filter(f_notice);filter(f_local0);destination(remote_server);};"
Hi Gilbert,
How about this?
sys syslog {
auth-priv-from notice
auth-priv-to emerg
console-log enabled
cron-from warning
cron-to emerg
daemon-from notice
daemon-to emerg
description none
include "
filter f_custom {
(level(notice))
destination d_loghost {
udp(\"x.x.x.x\" port(514));
log {
source(s_syslog_pipe);
filter(f_custom);
destination(d_loghost);
iso-date disabled
kern-from notice
kern-to emerg
local6-from notice
local6-to emerg
mail-from notice
mail-to emerg
messages-from notice
messages-to warning
remote-servers none
user-log-from notice
user-log-to emerg
Yes, that’s working great. Thanks TJ
