I need some help with irule (or any other solution that will help) I have to make my URLs shorter so I’m doing below remapping
`Code`
HTTP::uri [string map -nocase {"/" "/xxxxx"} [HTTP::uri]]
Original link looks like that: https://link.domain.com/xxxxx and after remapping https://link.domain.com/
It causing one problem – logo image located on this site disappear after remapping So this is effect of this remapping https://link.domain.com/images/logo.png but it should look like that https://link.domain.com/xxxxx/images/logo.png
how can I prevent it? of course i want to make my link shorter but i want to exclude such behavior.
The
string map
substitutes every instance of / for /xxxxx. Thus, if the path-uri were /, it would change the path-uri to /xxxxx. If the path-uri were /foo/bar, it would change the path-uri to /xxxxxfoo/xxxxxbar. I believe what you are attempting to do is insert a path element at the start of any submitted path-uri, so that:
Is that correct? If so, then you should be able to simply do this:
HTTP::uri "/xxxxx[HTTP::uri]"
If you are using BIG-IP 11.4 or higher, you could also use a Local Traffic Policy:
ltm policy expand-path {
controls { forwarding }
requires { http }
rules {
rule01 {
actions {
0 {
http-uri
replace
path /xxxxx[HTTP::uri]
ordinal 2
strategy first-match
