is it possible to force reloading the webtop or display the logoff page after Logout via Logout URI Include on an other tab?
I understand your request but for this kind of need it should be set up a java that can probe the service to see if it is UP or not.
so when you make a logout on your page, the other tab, probe if the session is still active and and triggers a logout.
but this solution requires a development is a rewrite of the page f5 if it is the VPNSSL or an insertion of java if it is Web access management …
by default the other tabs will be disconnected but only after the session timeout that you have set in your VPE.
regards
