I don’t see a way to request an update to the release notes without opening a case, is there a way? I don’t see bug
746861-1 : SFP interfaces fail to come up on BIG-IP 2x00/4x00, usually when both SFP interfaces are populated★
Component: TMOS
Symptoms:
The SFP interfaces do not come up or flap up and down repeatedly on BIG-IP 2000/4000 on boot up when both SFP interfaces are populated.
When interface flaps state changes such as those below are logged in ltm log:
info pfmand[PID]: 01660009:6: Link: 2.1 is UP
info pfmand[PID]: 01660009:6: Link: 2.1 is DOWN
Conditions:
Both SFP interfaces, 2.1 and 2.2, on BIG-IP 2000/4000 are populated.
This is typically observed after an upgrade to an affected version.
Impact:
Traffic cannot be sent/received from these interfaces.
Workaround:
None.
Listed on the release notes, but pretty sure i hit it today, update to 14.1.2.5-0.0.3 fixed the issue.
