I have a doubt between CPU , core and TMM. I read that CMP feature allows platforms that contain multiple CPUs to run a single TMM process for every CPU, and multiple TMM threads per processing core.
So i have a VIPRION 2250 blade which has : Cores per slot is 20, running only 1 VCMP guest and only 1 slot.
According to myF5 , we have the below:
1 Deca-core (+HT) - Processor 1 - TMM processer 10 - TMM threads (11.5.x) tmsh output shows 10 separate TMM instances (threads) running
Questions: 1. In the device above how does TMM process, TMM threads, processor and CPU collaborate? 2. I also see in the performance tab in CPU Utilization , I get 4 graphs with 4 core each, how is this calculated?
Thanks!
