reject not rejecting?
I have to be missing something simple here… setting up a new irule to do a simple whitelist. Here’s the whole thing (stolen shamelessly from somewhere else on DevCentral):
    if { [class match [IP::client_addr] equals trusted_ips] } {
        log local0. "[IP::client_addr]:[TCP::client_port]: Client is in data group so do not redirect. DG: [class get trusted_ips]"
        log local0. "[IP::client_addr]:[TCP::client_port]: Client is not in data group bail"
        reject
The “trusted_ips” datagroup has a single dummy entry, 1.2.3.4, not my requesting IP. When I try to hit the vip this irule is attached to, I get the destination page (a simple static page on an apache server), and the log entry:
Sun Dec 29 13:09:26 PST 2013 info slot1/DCA2400VPRA tmm1[9649]   Rule /Common/trusted_ips_only : 162.195.xxx.xxx:53465: Client is not in data group bail
So - the irule is executing, but the “reject” isn’t seemingly rejecting. I tried “discard” and “drop”, same behavior. (and HTTP::respond gave me back an error about HTTP or ICAP profiles that I can’t seem to find any docs on). What I’d really like is a 404 error, frankly.
I’ve been using irules in 10.2.4 for years - but this is on new iron, a Viprion running 11.4, and either something changed or I’m missing something simple somewhere, not for the first time.
Any tips? Thanks in advance for your time.
Did you check your cache on your browser ?
Are you using any proxy between your client and your BIG-IP ?
And last thing, maybe you can try to this iRule to send a 404 response :
        HTTP::respond 404
        HTTP::respond 404
can you try CLIENT_ACCEPTED instead of HTTP_REQUEST?
HTTP::respond gave me back an error about HTTP or ICAP profiles that I can’t seem to find any docs on.
have you assigned http profile to the virtual server?
No, no cache, no proxies - I can reproduce this with curl on the command line. Changing “reject” to “HTTP::respond 404” causes this error on trying to save the iRule: 01070394:3: HTTP::respond in rule (/Common/trusted_ips_only) requires an associated HTTP or ICAP profile on the virtual server (/Common/test). Interestingly - this is the error I’ve seen before, I thought at runtime. The profile associated with thisw VIP is the default you get when you select http and port 80 - “Performance (HTTP)” with “fasthttp” listed as the profile (the only choice there).
CLIENT_ACCEPTED has the same behavior - it logs that the connection is denied, but I still get back the content to the client. The virtual server profile is “fasthttp” - the only one visible in the dropdown. Here’s the actual config (slightly censored): ltm virtual /Common/test { description “test for bortels” destination /Common/63.xx.xx.xx:80 ip-protocol tcp mask 255.255.255.255 pool /Common/testweb profiles { /Common/fasthttp { } } rules { /Common/trusted_ips_only } source 0.0.0.0/0 translate-address enabled translate-port enabled }
Interestingly - if I change the type to “Standard” rather than “Performance (HTTP)” - this workd (in that I get rejected now, which was the expected behavior).
I guess this modifies the question a bit - why would choosing the Performance/fasthttp profile allow irule execution - but not honor the reject (silently!)?
The ugly continues - having seen it block, I add my IP into the datagroup - and it posts the “do not redirect” log line in the original script… but on the client… it just hangs until timeout. Very, very odd - never had these issues in 10.2.4; there’s got to be something fundamental I’m missing…
fasthttp profile does not work here too. i have not yet found existing bug. you can open a support case to confirm.
this is mine.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys version
Sys::Version
Main Package
  Product  BIG-IP
  Version  11.4.1
  Build    608.0
  Edition  Final
  Date     Wed Aug 14 17:23:43 PDT 2013
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.20.15:80
    ip-protocol tcp
    pool foo
    profiles {
        fasthttp { }
    rules {
        myrule
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 32
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
    when CLIENT_ACCEPTED {
  reject
  log local0. "reject"
 trace
[root@ve11a:Active:In Sync] config  tcpdump -nni 0.0 -s0 port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
16:21:56.224539 IP 172.28.20.20.47507 > 172.28.20.15.80: S 3556529537:3556529537(0) win 5840  in slot1/tmm1 lis=
16:21:56.224606 IP 172.28.20.15.80 > 172.28.20.20.47507: S 1313924097:1313924097(0) ack 3556529538 win 4380  out slot1/tmm1 lis=/Common/bar
16:21:56.226454 IP 172.28.20.20.47507 > 172.28.20.15.80: . ack 1 win 5840 in slot1/tmm1 lis=/Common/bar
16:21:56.227436 IP 172.28.20.20.47507 > 172.28.20.15.80: P 1:156(155) ack 1 win 5840 in slot1/tmm1 lis=/Common/bar
16:21:56.227650 IP 200.200.200.14.49961 > 200.200.200.101.80: S 2835644534:2835644534(0) win 4380  out slot1/tmm1 lis=/Common/bar
16:21:56.229374 IP 200.200.200.101.80 > 200.200.200.14.49961: S 1298715936:1298715936(0) ack 2835644535 win 5840  in slot1/tmm1 lis=/Common/bar
16:21:56.229394 IP 200.200.200.14.49961 > 200.200.200.101.80: . ack 1 win 4380 out slot1/tmm1 lis=/Common/bar
16:21:56.229402 IP 200.200.200.14.49961 > 200.200.200.101.80: P 1:156(155) ack 1 win 5840 out slot1/tmm1 lis=/Common/bar
16:21:56.231633 IP 200.200.200.101.80 > 200.200.200.14.49961: . ack 156 win 6432 in slot1/tmm1 lis=/Common/bar
16:21:56.232282 IP 200.200.200.101.80 > 200.200.200.14.49961: P 1:244(243) ack 156 win 6432 in slot1/tmm1 lis=/Common/bar
16:21:56.232363 IP 172.28.20.15.80 > 172.28.20.20.47507: P 1:244(243) ack 156 win 6432 out slot1/tmm1 lis=/Common/bar
16:21:56.233272 IP 172.28.20.20.47507 > 172.28.20.15.80: . ack 244 win 6432 in slot1/tmm1 lis=/Common/bar
16:21:56.234500 IP 172.28.20.20.47507 > 172.28.20.15.80: F 156:156(0) ack 244 win 6432 in slot1/tmm1 lis=/Common/bar
16:21:56.234510 IP 172.28.20.15.80 > 172.28.20.20.47507: F 244:244(0) ack 157 win 4380 out slot1/tmm1 lis=/Common/bar
16:21:56.235416 IP 172.28.20.20.47507 > 172.28.20.15.80: . ack 245 win 6432 in slot1/tmm1 lis=/Common/bar
16:21:56.333705 IP 200.200.200.14.49961 > 200.200.200.101.80: . ack 244 win 4380 out slot1/tmm1 lis=/Common/bar
 /var/log/ltm
[root@ve11a:Active:In Sync] config  tail /var/log/ltm
Dec 30 16:21:56 ve11a info tmm1[2836]: Rule /Common/myrule : reject
it seems it does not work in 10.2.4 too.
config
root@ve10(Active)(tmos) show sys version |grep -A 6 Main\ Package
Main Package
  Product  BIG-IP
  Version  10.2.4
  Build    817.0
  Edition  Hotfix HF7
  Date     Mon May 20 15:08:56 PDT 2013
root@ve10(Active)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.20.17:http
    ip-protocol tcp
    pool foo
    profiles {
        fasthttp { }
    rules {
        myrule
    snat automap
root@ve10(Active)(tmos) list ltm rule myrule
ltm rule myrule {
  reject
 trace
[root@ve10:Active] config  tcpdump -nni 0.0 -s0 port 80
10:52:38.784277 IP 172.28.20.20.51828 > 172.28.20.17.80: S 4111390735:4111390735(0) win 5840  in slot1/tmm0 lis=
10:52:38.784329 IP 172.28.20.17.80 > 172.28.20.20.51828: S 413864687:413864687(0) ack 4111390736 win 4380  out slot1/tmm0 lis=bar
10:52:38.785331 IP 172.28.20.20.51828 > 172.28.20.17.80: . ack 1 win 5840 in slot1/tmm0 lis=bar
10:52:38.785337 IP 172.28.20.20.51828 > 172.28.20.17.80: P 1:156(155) ack 1 win 5840 in slot1/tmm0 lis=bar
10:52:38.785441 IP 200.200.200.16.65423 > 200.200.200.101.80: S 3491750769:3491750769(0) win 4380  out slot1/tmm0 lis=
10:52:38.786573 IP 200.200.200.101.80 > 200.200.200.16.65423: S 920090142:920090142(0) ack 3491750770 win 5840  in slot1/tmm0 lis=
10:52:38.786583 IP 200.200.200.16.65423 > 200.200.200.101.80: . ack 1 win 4380 out slot1/tmm0 lis=
10:52:38.786588 IP 200.200.200.16.65423 > 200.200.200.101.80: P 1:156(155) ack 1 win 5840 out slot1/tmm0 lis=
10:52:38.787350 IP 200.200.200.101.80 > 200.200.200.16.65423: . ack 156 win 6432 in slot1/tmm0 lis=
10:52:38.788472 IP 200.200.200.101.80 > 200.200.200.16.65423: P 1:244(243) ack 156 win 6432 in slot1/tmm0 lis=
10:52:38.788483 IP 172.28.20.17.80 > 172.28.20.20.51828: P 1:244(243) ack 156 win 6432 out slot1/tmm0 lis=bar
10:52:38.789596 IP 172.28.20.20.51828 > 172.28.20.17.80: . ack 244 win 6432 in slot1/tmm0 lis=bar
10:52:38.789607 IP 172.28.20.20.51828 > 172.28.20.17.80: F 156:156(0) ack 244 win 6432 in slot1/tmm0 lis=bar
10:52:38.789613 IP 172.28.20.17.80 > 172.28.20.20.51828: F 244:244(0) ack 157 win 4380 out slot1/tmm0 lis=bar
10:52:38.791293 IP 172.28.20.20.51828 > 172.28.20.17.80: . ack 245 win 6432 in slot1/tmm0 lis=bar
10:52:38.889555 IP 200.200.200.16.65423 > 200.200.200.101.80: . ack 244 win 4380 out slot1/tmm0 lis=
 /var/log/ltm
[root@ve10:Active] config  tail /var/log/ltm
Dec 31 10:52:38 local/tmm info tmm[4922]: Rule myrule : reject
