Hi Guys,
We have a requirement to allow certain Device ID to initiate ActiveSync traffic normally and reject other device IDs
We followed the same irule here MS Exchange Active Sync Device Auth - Community CodeShare - DevCentral - An F5 Technical Community
But just we changed the last line instead of "ACCESS::session remove " to be “Reject” , but not working fine
Once we removed one of Device ID from data group and add it again , it is getting rejected , once we removed “Reject” statement the device is able to work fine with active sync , So I don’t know the reason for that
BTW , VS has APM , ASM policies
# Apply DeviceID restriction to all ActiveSync directory traffic
if {[HTTP::path] == “/Microsoft-Server-ActiveSync”} {
# Determine whether connection is Base64 encoded, (Windows Phone) and if necessary begin decoding process
set string_b64encoded [HTTP::query]
if {[catch {b64decode $string_b64encoded} string_b64decoded] == 0 and $string_b64decoded ne “”} {
binary scan $string_b64decoded x4H2 IDlenHEX
scan $IDlenHEX %x IDlenDEC
set IDlen [expr “$IDlenDEC * 2”]
binary scan $string_b64decoded x5H$IDlen HEXdeviceID
set string_sentid [string toupper $HEXdeviceID]
set string_sentid [string toupper [URI::query [HTTP::uri]]]
# compare deviceID presented in HTTP::query with BigIP Data Group List - ‘devices’
if {[class match $string_sentid contains devices]} {
log local0.info “Successful login with deviceID: $string_sentid”
log local0.info “Failed login with deviceID: $string_sentid”
reject
