Simply put, I’m trying to use matches_regex to locate a string that will be terminated with a control character, <0x0d> (the carriage return) to be precise.
I’ve tried using “\r”, “[:ctrl:]”, and even putting “<0x0d>” within the expression. None of that has worked. What can I add to my regex so that the carriage return, or at least a class of characters that contains the carriage return, will be looked for?
Thanks!
