Regular Expression - HTTP URI
How can i match on following :
-http://www.xyz.com/abc/“anything” >>> I want to match on .xyz Domain Names | Join Generation XYZ with anything after “/abc/”
-http://www.xyz.com/abc/QW"anything" >>> I want to match on .xyz Domain Names | Join Generation XYZ with anything after “QW”
-http://www.xyz.com/abc.aspx?cal=“anything” >>> I want to match on any value @ the Query string “cal”
you may try scan command.
% set uri1 "/abc/anythig"
/abc/anythig
% scan $uri1 {/abc/%s} var1
1
% put $var1
anythig
iRules 101 - 16 - Parsing Strings with the TCL Scan Command by Jason Rahm
URI::query
[root@ve11c:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
    when RULE_INIT {
  set uri1 "/abc.aspx?cal=anything"
  log local0. "URI is $uri1 and parameter cal value is [URI::query $uri1 cal]"
[root@ve11c:Active:In Sync] config  tail -f /var/log/ltm
Apr 12 15:55:39 ve11c info tmm1[5649]: Rule /Common/qux : URI is /abc.aspx?cal=anything and parameter cal value is anything
Here is an iRule that I shared with a few customers:
        if { [HTTP::uri] starts_with "/abc"} {
                  set path [HTTP::uri]
                   variable loc marks the "Second" occurrence of a '/'.  This will drop /abc
                   if you want to drop /abc/xyz, locate the "Third" occurence of '/' by changing 1 to 2 at
                  set loc [string first "/" $path 1]
                  set path_minus_root [string range $path $loc end]
                  Note:  the value of variable path_minus_root will start with a '/'
                  HTTP::redirect "https://www.company.com/new_site/qux$path_minus_root"
You can also do this job using the [URI::path [HTTP::uri]] commands which are very useful.
