I have copied the Backup .UCS file from 3400 F5 and restore this Backup file on 8900 . with this it has overwrite every thing my intentions were for Configuration. now 8900 GUI is displaying me the activation screen for License.
and i don’t have support from F5 as machines are end of life. kindly tell me how to restore previous 8900 .UCS file so that the Reg Key and License for 8900 restored.
you can do it in command line, can’t you?
sol13132: Backing up and restoring BIG-IP configuration files (11.x)
by the way, license file and registration key (inside license file) are included in ucs. you can use tool such as 7zip to extract the ucs file.
thanks for quick reply 8900 is with version 10.X and 3400 was 9.4.5 . and i have access to command line. u are saying that i can extract 8900 Reg key and License through 8900 backup .ucs file
