Regex issue
Hello,
I am stuck on trying to find out how to match some parameters in a WAF request using regex wildcard
The parameters that I want to match are int the form of amp;arg20=something where the arg20 can be anything.
The repetitive part that I want to match with the regex is amp; and I want to match multiple times because it appears multiple times in the query string
This is the request
<span class=""><span class="">GET /human.aspx?r=2900376326&</span></span><span class=""><a class="" href="https://10.179.136.48/dms/policy/requests_ng.php#" target="_blank" rel="noopener nofollow noreferrer">amp;arg20=dssdds</a></span><span class=""><span class="">&</span></span><span class=""><a class="" href="https://10.179.136.48/dms/policy/requests_ng.php#" target="_blank" rel="noopener nofollow noreferrer">amp;arg21=aaa</a></span><span class=""><span class=""> HTTP/1.1</span></span>
I want to match the 2 parameters amp;arg20 and amp;arg21 with a wildcard which appears as invalid parameters
Parameter Location Query String
Parameter Name amp;arg20
Parameter Value dssdds
Applied Blocking Settings Block Alarm Learn
Parameter Name amp;arg21
Parameter Value aaa
I tried to create multiple wildcard parameters like: amp.* or amp.+?(?==) but the parameters never match and I get the illegal parameter violation
How can this be achieved?
I attahced the wildcard parameter entry that I have created
You can try this:
amp;arg2[01]
This site can help you test your regular expressions:
regex101: build, test, and debug regex
Hello,
Thank you for your answer.
I tried it and it still doesn’t work.
Anyway there is the posibility that the parameters in the request will be amp;Arg02 or amp;arg100 or even amp;Opt10
The regex in my opinnion should match any parameter that starts with this string amp; and then anything else untill the = sign
I also tried it on the regex website and even on the f5 regex tester and the regex appears to be ok but when I try to use it in the policy it fails
This?
amp;[a-zA-Z0-9]+=
Same
Just to be sure that I am doing it correctly I attached the parameter creation page and the error that I get
I somehow got it to work with this solution (not sure why it wasn’t working before)
amp;[a-zA-Z0-9]*
Nice!
