Referencing pool/virtual from another iApp
I have written an iRule that selects the pool based on the IP of the source. I am trying to add this iRule to an iApp, however it tells me if can’t find one of the pools. This pool is part of another iApp. How can I reference a pool from another iApp?
Hi Patrick, have you tried referencing the pool using the full partition and path within the iRule, for example “pool /Common/my_app.app/my_app_pool”?
Can you post the iRule here?
thanks
Mike
Using the full path worked. Thanks!
