[split from an initial post, by Ravi]
Now I am facing other issues:
1) I have two F5 devices configured in failover mode. Earlier it was showing one as “Active” and other as “StandBy” but now both are showing as “Active”. I am suspecting this becuase my “Rediscover configuration for F5 Device” task is failing. Please correct me if I am wrong.
Ravi
Hi Ravi,
We know about this problem, when discovering F5 devices configured in fail-over mode. The initial discovery may show the “StandBy” peer as “Active” and the correct fail-over state is not discovered until a change is received. So they always display as “Active” (or no fail-over state recorded) when you initially discover. And this would stay the same, regardless if you’ll force a [new] rediscovery. A new change on the device will trigger though the correct state.
Julian
Thanks julian! for your help.
