It works GREAT. My issue now is I need to be able to add subdomain.testdomain.org, testdomain.net, etc. Creating a 2nd rule doesn’t help. I tried combining them and separating them with an ‘or’ but got errors. I tried downloading the iRule editor but the download link seems to just loop back to where you start. I need this rule because the SSL cert on the F5 is only for www.testdomain.com and the rule prevents the cert error that makes end-user think there’s some issue. Please help, I’m an iRule idiot.
I tried to use an elseif to add the subdomain.testdomain.com and it is appending www.subdomain.testdomain.com which does NOT exist. So I am close but no cigar. I see ‘why’ it did it but I"m not sure how to fix. Here’s what I tried that didn’t quite work:
I think what you’re looking for is something like:
set userhost [HTTP::host]
if { $userhost equals "testdomain.org"} {
set userhost "www.[HTTP::host]"
} elseif { $userhost equals "ml.testdomain.org"} {
set userhost "[HTTP::host]"
} elseif { $userhost equals "testdomain.net"} {
HTTP::redirect "https://$userhost[HTTP::uri]"
Note that the way you’re manipulating userhost changes depending on what it was set to coming from the client. If you see subdomain.testdomain.org, you’re not going to want to prepend a www to it. If you see just testdomain.org or testdomain.net, then you will.
