I’m having problem with the following iRule. I does not work. It looks like it’s not trying even the first condition:
log local0. "Client [IP::client_addr]"
if { ([IP::addr [IP::client_addr] equals x.x.x.x]) and ([HTTP::uri] eq "/someuriwithparameters*") }
{ log local0. "Client [IP::client_addr] matched case 1"
pool POOL1 }
if { ([IP::addr [IP::client_addr] equals y.y.y.y]) and ([HTTP::uri] eq "/someuriwithparameters2*") }
{ log local0. "Client [IP::client_addr] matched case 2"
pool POOL1 }
It just drops “Client x.x.x.x” to /var/log/ltm but nothing happens, redirection doesn’t work… I’ve tried IP:addr conditions and HTTP:uri with brackets “()” and without. No change at all.
Any mistake in code here?
Thanks, Tomek
A few []'s in the wrong place. Also, you can’t use wildcards with an ‘equals’.
if { ( [IP::addr [IP::client_addr]] equals "x.x.x.x" ) and ( [string tolower [HTTP::uri]] starts_with "/someuriwithparameters" ) } {
pool POOL1
if { ( [IP::addr [IP::client_addr]] equals "y.y.y.y") and ( [string tolower [HTTP::uri]] starts_with "/someuriwithparameters2" ) } {
pool POOL1
Hi, it drops an error: “01070151:3: Rule [iRule_Backend_Access_2] error: line 3: [wrong args] [IP::addr [IP::client_addr]] line 10: [wrong args] [IP::addr [IP::client_addr]]”
is that because we use routing domains?
Apologies IP::addr always catches me out. This should work;
if { ( [IP::addr [IP::client_addr] equals x.x.x.x] ) and ( [string tolower [HTTP::uri]] starts_with "/someuriwithparameters" ) } {
pool POOL1
if { ( [IP::addr [IP::client_addr] equals y.y.y.y] ) and ( [string tolower [HTTP::uri]] starts_with "/someuriwithparameters2" ) } {
pool POOL1
Your script looks more or less the same as mine
Unfortunately, it seems that function: [IP::addr [IP::client_addr] equals y.y.y.y] does not work, when routing domains are used.
Without additional parsing/formating it wouldn’t extract dotted decimal IP. I’ve decided to use just [IP::client_addr] with % notation added. It’s ok, but… I was suprised that this function is not rounting domain aware.
Hmmm, I’ll have to keep that in mind for the future. It makes sense really as there needs to be a default and I assume that’s common. You wouldn’t want it to randomly detect a RD as you may have two using the same address space.
