Redirecting to a pool
I m having a problem with an iRule.
I m trying to redirect the below “Source” URL to “Destination” URL(NOTE: Here * could be any sub URI)
Source:
.xyz Domain Names | Join Generation XYZ*
Destination:
http://hello.XYZ.com:9090/\*
Below is the iRule which I m trying, but unfortunately it is not working.
when HTTP_REQUEST priority 10 {
switch -glob [HTTP::path] {
“/stproxy*” { pool hello_9090_Pool }
Can anyone help on this?
Best Regards,
I m sorry, the actual iRule which I m using is as below
“/123*” { pool hello_9090_Pool }
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   destination 172.28.19.79:http
   ip protocol tcp
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
   if {[string tolower [HTTP::uri]] starts_with "/123/"} {
      HTTP::redirect "http://[string map {www hello} [HTTP::host]]:9090[HTTP::uri]"
[root@ve10:Active] config  curl -I http://www.XYZ.com/123/something
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Are you looking to “redirect”, or simply use the pool members which listen on a different port(9090)? If you do not want to redirect, but use the pool you have in your iRule, you may have to correctly set the Host header on all requests to hello.XYZ.com or configure the pool members to listen for requests for www.XYZ.com in your example. This would be the case if you are taking requests for www.XYZ.com and load balancing them to a pool of servers that are accepting connections only for Host header hello.XYZ.com
Eric
sorry i forgot to remove /123 in redirection. this is the revised one.
rule myrule {
      HTTP::redirect "http://[string map {www hello} [HTTP::host]]:9090[string map {/123/ /} [HTTP::uri]]"
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
and this is an example based on Eric’s suggestion.
virtual bar {
   snat automap
   pool foo
   ip protocol tcp
   rules myrule
   profiles {
      http {}
      tcp {}
rule myrule {
      HTTP::header replace Host "[string map {www hello} [HTTP::host]]:9090"
      HTTP::uri [string map {/123/ /} [HTTP::uri]]
[root@ve10:Active] config  b pool hello_9090_Pool list
pool hello_9090_Pool {
   members 200.200.200.101:websm {}
[root@ve10:Active] config  ssldump -Aed -nni 0.0 port 80 or port 9090
New TCP connection 1: 172.28.19.251(35477) <-> 172.28.19.79(80)
1341155212.1407 (0.0011)  C>S
HEAD /123/something HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: www.XYZ.com
Accept: */*
New TCP connection 2: 200.200.200.10(35477) <-> 200.200.200.101(9090)
1341155212.1428 (0.0018)  C>S
HEAD /something HTTP/1.1
Host: hello.XYZ.com:9090
Accept: */*
