Redirecting out of HTTPS
I want to redirect out of https if the customer is in https and clicks on certain links or request is in a list of uri that are not in my https strings list. but I don’t want to to be redirected if the request is of a certain file type. What i have so far and it’s not working is the following.
set inbound_uri [string tolower [HTTP::uri]]
if {([matchclass $inbound_uri ends_with $::test_ends_with])}{
basically if it ends with example .jpg or .swf do nothing leave them in ssl
return
elseif {([matchclass $inbound_uri starts_with $::test_rewards])}{
if request matches my links that should not be https it redirects you.
HTTP::redirect http://[HTTP::host][HTTP::uri]
elseif {not ([matchclass $inbound_uri starts_with $::test_https])}{
if the request isn’t in my https list then redirect them
Is the SSL terminating on the BIGIP or is it on the pool member?
CB
terminating on the f5. Looks like it worked but there was a conflicting irule on the http side redirecting some back to the https side.
After i fixed that problem it looks like there are some external webtrend links that we’re sending in regular http, so the user got a message saying some parts of the page we’re not ssl , so I did a http_reponse rewrite that changed everythign to https. and now there is a certificate error on the page because the webtrends image is coming from an ssl site that doesn’t match the url in the user browser.. Any ideas on how to fix that other then removing the external webtrends tracking images from an ssl site?
I didn’t think most browsers would generate a security warning if certain content was served via HTTPS from a non-local domain. If you use HttpFox for Firefox or Fiddler for IE, what request generates the warning? What is the exact text of the warning?
Aaron
So, there wouldn’t be a certificate error usually if an ssl page had content from two separate ssl sites if one doesn’t match the url you went to in the address bar?
lets say I went to https://www.americanexpress.com and inside that page there is an image from Webtrends Analytics — Webtrends.
Maybe my rewrite code is too all inclusive I used
when HTTP_RESPONSE {
STREAM::disable
if {[HTTP::header value Content-Type] contains “text”}{
STREAM::expression {@[hH][tT][tT][pP]://@https://@}
STREAM::enable
Posted By robert.henson@fishnetsecurity.com on 09/15/2009 7:34 AM
Correct. That’s what I’ve seen. If you’re still getting a cert warning, can you use a browser plugin, wait for the error message, clear the logs and then click okay on the warning to load the content. You should then see the request which is triggering the error.
What is the exact error message? What is the request being made to and is it http:// or https://?
Aaron
fiddler didn’t show any errors? But if we use IE to goto the page it has a bar pop-up at the top says problems with the certificate? it is because we have some certificates that are local for testing and trusting manually and some from webtrends and sharethis are real?
this is the content after accepting the errors.
CONNECT stage.test.com:443 HTTP/1.0
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; InfoPath.2; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8)
Proxy-Connection: Keep-Alive
Content-Length: 0
Host: stage.test.com
Pragma: no-cache
________________________________________
Content-Length: 0
Proxy-Authorization: NTLM TlRMTVNTUAABAAAAB7IIogoACgAxAAAACQAJACgAAAAFASgKAAAAD0hPTDAwMjE1MUhPTUVPRkZJQ0U=
Pragma: no-cache
The data sent represents an SSLv3-compatible ClientHello handshake. For your convenience, the data is extracted below. Major Version: 0 Minor Version: 0 Random: null SessionID: null Ciphers: null
CONNECT w.sharethis.com:443 HTTP/1.0
Content-Length: 0
Host: w.sharethis.com
Pragma: no-cache
Content-Length: 0
Pragma: no-cache
Content-Length: 0
Pragma: no-cache
Content-Length: 0
Pragma: no-cache
I’d guess that’s an indication from the browser of an improperly chained server certificate--not an issue with some of the content being served from an external domain.
If you use a cert issued by a cert authority that the browser already has installed by default, the warning won’t appear. Or if you have control over the client browser(s), you could install the root cert and the cert would be accepted. For a CA issued cert you may need to configure LTM to send a chain cert which ties the server cert to a root cert in the browser.
Aaron
So in production environment with a valid certificate from a valid CA like entrust we wouldn’t be seeing this error?
I would think so, assuming it’s just an error about the cert not being chained to a valid root certificate.
Do you get an error like “There is a problem with this website’s security certificate.”? If you accept the warning and then click on the lock icon to view the server cert, what do you see on the last tab for “Certification Path”?
Aaron
