I have other links that is going to come from other app owners that wants to stay within the old site and keep users there until they move the content over to the new site.
I have other links that is going to come from other app owners that wants to stay within the old site and keep users there until they move the content over to the new site.is it something like this?
e.g.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.252:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b rule myrule list
rule myrule {
if { [string tolower [HTTP::host]] equals "oldsite.com" } {
set uri [string tolower [HTTP::uri]]
if { $uri equals "/" } {
HTTP::respond 302 noserver Location "https://landingpage.com"
} elseif { not ($uri starts_with "/it/useradmin/") } {
HTTP::respond 302 noserver Location "https://newsite.com[HTTP::uri]"
[root@ve10:Active] config curl -I http://172.28.19.252 -H "Host: oldsite.com"
HTTP/1.0 302 Found
Connection: Keep-Alive
Content-Length: 0
[root@ve10:Active] config curl -I http://172.28.19.252/something -H "Host: oldsite.com"
HTTP/1.0 302 Found
Content-Length: 0
[root@ve10:Active] config curl -I http://172.28.19.252/it/useradmin/something -H "Host: oldsite.com"
HTTP/1.1 404 Not Found
Date: Tue, 06 Aug 2013 04:26:09 GMT
Server: Apache/2.2.3 (CentOS)
Content-Type: text/html; charset=iso-8859-1
The script that I have working right now is the one dated 8/1/13, the redirection will still stay the same. Now we have customers that we will need to keep on the old site like you mentioned, how can I add this to the existing script:
This works great but I need to add that script above to this..
I need to add that script above to this.. actually, it is already added. since it does nothing on “/it/useradmin/”, i collapses it by using 'not". the following is when not using “not”.
} elseif { $uri starts_with "/it/useradmin/" } {
do nothing
for http://www.oldsite.com/it it does not work but for https:///www.oldsite.com/it it works. Can I get a redirect added to this script to make sure that users are redirected to the site. Right now just comes up with page not found.
I actually put a /it/* to accept everything after that. That tends to work fine.
for http://www.oldsite.com/it it does not work i thought you want “/it/useradmin/*”. if it is “/it/*”, you can just change from “/it/useradmin/” to “/it/” in the irule.
if they go to https://ww.oldsite.com they stay at oldsite.com. I need them to go to landingpage.com as well. i understand you have 2 virtual servers; one is 80 and the other one is 443, haven’t you? what irule do you apply to 443 virtual server?
e.g.
[root@ve10:Active] config b virtual bar80 list
virtual bar80 {
snat automap
pool foo
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b virtual bar443 list
virtual bar443 {
snat automap
pool foo
destination 172.28.19.252:443
ip protocol 6
rules myrule
profiles {
clientssl {
clientside
http {}
tcp {}
rule myrule {
} elseif { not ($uri starts_with "/it/") } {
http
[root@ve10:Active] config curl -I http://172.28.19.252/ -H "Host: oldsite.com"
HTTP/1.0 302 Found
Content-Length: 0
HTTP/1.0 302 Found
Content-Length: 0
[root@ve10:Active] config curl -I http://172.28.19.252/it/something -H "Host: oldsite.com"
Date: Thu, 08 Aug 2013 01:47:16 GMT
https
[root@ve10:Active] config curl -Ik https://172.28.19.252/ -H "Host: oldsite.com"
HTTP/1.0 302 Found
Content-Length: 0
[root@ve10:Active] config curl -Ik https://172.28.19.252/something -H "Host: oldsite.com"
HTTP/1.0 302 Found
Content-Length: 0
[root@ve10:Active] config curl -Ik https://172.28.19.252/it/something -H "Host: oldsite.com"
Date: Thu, 08 Aug 2013 01:47:33 GMT
