Redirect without path rewriting
Hello,
A company wants to use local link accessing public resource, but after redirect url path shouldn’t change to external and stay local. Another words, it is possible dynamically rewrite public url into local, so users work with remote site as with local?
Yep, it can be done
  if { ( [HTTP::host] == "fqdn.clientside.int" ) && ( [HTTP::path] == "/" ) }{
    HTTP::host "www.foo.com"  Rewrite the HTTP Host header value, before routing the request to a pool-member.
    HTTP::path "/blabla"  Rewrite the request path (Use if path masking is needed).
Yep, it can be done
This solution is a feasible option if the public webside is an applet, or a HTML website with relative hyperlinks only. If it’s a HTML website which includes full links (containing original Host value), it will not be enough.
Thx Hannes, will check it.
