I have APM running, Share Point is the pool. Both internal and external users hit the same VIPs. There is a resource which is a link in Share Point. The resource internally supports Kerberos SSO (KerberosURL). The same resource supports Forms SSO (FormsURL) for external customers, however the only URL available in Share Point is the SSO KerberosURL. What I wouldl like to use an iRule to do is when external customers login and select the URL I want only those customers redirected to the SSO Forms URL.
Are you referring to an APM portal link or some link inside SharePoint itself? How would one access the FormsURL?
Hi Kevin. If I am understanding correctly, even though we are doing Portal Rewrite to access Share Point, it is not an APM portal link but a link inside Share Point. The Forms URLs is an internal URL that points to the Oracle Web Gate that supports forms. It can only be accessed from the internal network.
