Redirect two conn to pool, and other conn to default pool
Hi!,
I Need a IRule to redirect the connections of two ip’s to a pool, and other connections to another pool.
I tested with:
When HTTP_REQUEST {
if { [IP :: addr [IP :: client_addr ] equals xxxx ]} {
my pool pool_id
} Else if {[ IP:: addr [IP :: client_addr ] equals xxxx ]} {
my pool pool_id
No work, no redirects
The problem is that there is a proxy in the middle and translates the source addresses.
Need the same for a VS with port 443
I need Help! haha, please!
A. Diezma
does proxy insert x-forwarded-for header?
if yes, can you try this?
Route Traffic Based on Header Info
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1176873/showtab/groupforums/Default.aspx
No problem with “xff”. I will try.
thank you very much
Great! it works!
I applied:
When HTTP_REQUEST {
if {[HTTP:: header “X-Forwarded-For”] contains “x.x.x.164”} {
pool my_pool }
elseif {[HTTP:: header “X-Forwarded-For”] contains “x.x.x.167”} {
pool my_pool }
WEB} else {pool default_pool
Now I need another just to VS_port 443
Thanks a lot!!
Antonio
I also had to apply the profile http-xff
just in case there is more than one x-forwarded-for header.
Using X-Forwarded-for to block Clients?
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1174108/showtab/groupforums/Default.aspx
cheer!
Don’t use xff for blocking, only for testing website
Again, thank you very much
Solved!
Don’t use xff for blocking, only for testing website sorry i did not explain well. actually, i just want to point how we parse x-forwarded-for header if there is more than one.
