I’m pretty new to irule. I’m trying to access two different web instances using URIs. Requirement is to use single VIP. e.g.,
http://www.mycompany.com/ ;goes to pool1:port1
http://www.mycompany.com/app2 ;goes to pool2:port2 with no app2 in url
Both web instances are on same server(s) listening on two different TCP ports and have their own index.html. I have created pool1 and pool2 with following irule:
if [string tolower [HTTP::path]] eq “/app2”}{
pool Pool_2
}else {
pool Pool_1
The problem is that I can only get to pool2 by using a file called “app2” in the 2nd web instance folder and “app2” word is visible. I have also tried: HTTP::redirect “http://[HTTP::host]/” after pool pool_2 but that goes to pool1.
How do I get F5 to send it to /index.html for second web instance for http://www.mycompany.com/app2 request and remove “app2” from the URL?
Any help is appreciated very much. Thanks.
Hi AFara2000,
You could change the URI in the following manner
switch [string tolower [HTTP::uri]] {
"/app2" {
HTTP::uri /[HTTP::uri]
pool Pool_2
default {
pool Pool_1
I used the switch command because in the long run it executes faster then IF-ELSE.
I hope this helps
Bhattman
Thanks Bhattman for your code but that didn’t take care of /app2 in uri. I decided to use /app2/* for all web application 2 paths. Therefore, I modified your code and this seems to be working fine:
-glob: allow string pattern matching to check within requested path
switch -glob [string tolower [HTTP::path]] {
“/app2” {
log local0. “Exact macth for /app2 - sending to pool_2 in [HTTP::uri]”
HTTP::uri [HTTP::uri]/
pool Pool_2
“/app2/*” {
log local0. “Matched /app2/* - No rewrite, sending to pool_2 for [HTTP::uri]”
pool Pool_2
default {
log local0. “No match for app2, sending to default pool_1 for [HTTP::uri]”
pool Pool_1
My next step is to expand this code to use https instead of http. Can this code still be used? I will be planning to terminate SSL using clientside and serverside SSL certs. Any hint or help would be highly appreciated. Thanks,
Al
