Redirect to Maintenance page iRule help
All,
I need to apply an iRule to 3 HTTP and 3 HTTPS VIP’s. I want the iRule to redirect users to a maintenance page if none of the pool members are available.
I found this:
when CLIENT_ACCEPTED {
if { [active_members [LB::server pool]] == 0 } {
HTTP::redirect “http://maintenance_site.com” }
My questions are:
- will the above work for both HTTP and HTTPS VIP’s?
- is ‘server pool’ an actual F5 generic command? Or should I be specifying the pool name
- if ‘server pool’ is an F5 command, then I assume I can use this 1 iRule for all of my VIPs
Hi J Saunders,
- Will the above work for both HTTP and HTTPS VIP’s?
Yes.
- Is ‘server pool’ an actual F5 generic command? Or should I be specifying the pool name
Yes. In this situation you are specifically using LB::server pool, which returns the pool of the currently selected member.
- If ‘server pool’ is an F5 command, then I assume I can use this 1 iRule for all of my VIPs
Yes. It would dynamically detect the information.
If you would like to verify you can add a logging statement and then look in your LTM Log:
log local0. "Server Pool:  [LB::server pool]"
HTTP::redirect "http://www.google.com"
Hope this helps.
Awesome! Thanks for the clarifications.
Don’t forget to set the HTTP response code on the maintenance page to 503. You don’t want to run the risk of having Google index your maintenance page (makes the Marketing folks really cranky)…
