I have setup the timer using the ‘after’ command inside HTTP_REQUEST which I then cancel in HTTP_RESPONSE. I detect timeout and take node out of the mix. I then need to redirect request to another url, however both HTTP::redirect and HTTP::response give me the following errors:
- Illegal argument. Can’t execute in the current context. (line 1) invoked from within “HTTP::redirect $theUrl”
- Illegal argument. Can’t execute in the current context. (line 1) invoked from within “HTTP::respond 302 Location “$theUrl””
I have been looking at your iRule. The first thing that I am noticing is that you are setting variables in the RULE_INIT event that are being reset in the CLIENT_ACCEPTED Event and then again in the HTTP_REQUEST Event.
The RULE_INIT is triggered when an iRule is added or is modified.
The CLIENT_ACCEPTED is triggered for each client when they connect to the Virtual Server hosting the iRule the first time.
So you are doing some work twice for nothing when you could just do them in the HTTP_REQUEST event (since you are resetting them for each individual request anyway).
These are the ones I am referring to:
set theUrl “”
set retry 0
set server_addr “”
set server_port “”
set host_name “”
set host_uri “”
set host_port “”
set host_port_str “”
set host_protocol “”
set postBackUrl “”
As far as your error, can reproduce the error, but I am wondering if the illegal argument error that you are getting is due to something missing.
What does the logging statement show in your LTM Log:
log local0.debug “2. Redirecting to $theUrl”
Does it appear to be the correct URL that it should be?
Thanks for your reply. Yes, I’ve tried the “&”, and LTM has choked on the syntax:
Rule Smart_LB_Rule : 1. Taking node 10.2.178.121:8001 out of the mix …
TCL error: Smart_LB_Rule - invalid command name “host=10.2.178.121&” while executing “host=$server_addr&”
Funny thing is that this scenario works fine inside LB_FAILED (when server is down), and I do get redirected to the controller url. The same goes for HTTP_RESPONSE when I detect http code > 500. I have a feeling it’s the “after” command pecularities which prevent me from doing redirect.
Thank you,
Roman
PS: You must have edited your post while I’ve been trying your suggestion
PS: You must have edited your post while I’ve been trying your suggestion :)yes, it seems devcentral does not like triangle bracket. so, i had to edit my post.
Thank you very much for looking into my messy rule. Yes, you’re abs right, and I do need a lot of cleaning to do. I will as soon as I get it working, I promise.
As far as the url, this is what I see in the logs (masking sensitive data):
Rule Smart_LB_Rule : In lb_selected, server is server.ip.address:8001 …
Rule Smart_LB_Rule : *** Timeout after 15000 ms ***
Rule Smart_LB_Rule : 1. Taking node server.ip.address:8001 out of the mix …
Rule Smart_LB_Rule : 2. Redirecting to http://domain_name.company_name.com/controller/?source=ltm&action=restart&host=server.ip.address&service=/bad/&port=8001&name=&cause=no_response_from_server_after_15000_ms&postBack=http://domain_name.company_name.com/bad/
TCL error: Smart_LB_Rule - Illegal argument. Can’t execute in the current context. (line 1) invoked from within "HTTP::redirect $theUrl "
The url is valid, and if I put it in the browser, it works just fine. It also works (the HTTP::redirect $theUrl command) from inside both LB_FAILED and HTTP_RESPONSE events (as I’ve described to nitass). I have a sneaky suspicion it’s the “after” timer that is giving me a trouble.
Sorry, I didn’t see TCP::respond in your post. I’ve tested my rule with it a dozen times, and it seems to be working fine! I’m pretty sure I’ve tried the TCP::respond beforehand, but I guess I didn’t have the complete syntax
The solution is there, but did anyone ever determine why the HTTP::redirect is being executed within the CLIENT_ACCEPTED context, as the error message states? Why isn’t it being executed only within the HTTP_RESPONSE or HTTP_REQUEST contexts?
What is it about using “after” and a timeout period that seems to cause the code to be run in the CLIENT_ACCEPTED context?
I have a similar rule that uses an after that periodically triggers a similar error (only difference is that I’m trying to use HTTP::respond). I put the command in the HTTP_REQUEST context, yet it’s being triggered in the CLIENT_ACCEPTED context.
not sure if i catch you correctly. anyway, i am also wondering what context after’s script is running is.
for example, when using HTTP::redirect instead of TCP::respond in the following example, i got context error.
send response from BigIP if server does not respond within a specified amount of time
/var/log/ltm
Aug 10 15:30:03 local/tmm info tmm[4860]: Rule myrule : Timeout 1000 milliseconds elapsed without server response. 1344583803
Aug 10 15:30:03 local/tmm err tmm[4860]: 01220001:3: TCL error: myrule - Illegal argument. Can’t execute in the current context. (line 1) invoked from within “HTTP::redirect “http://www.google.com/””
i think i will open a case to verify unless someone here can give me a shot.
