Redirect SharePoint 2007 subsite to 2010 almost working (using iRules)
I’m trying avoid a full cutover of all sites to SharePont 2010 from 2007. I’ve been experimenting with ProxyPass and other iRules to redirect an individual site from 2007 to 2010. In all iRule test cases, most everything except for the Ribbon and the Site Action dropdown are working. Has anyone been successful with this? If so, what’s the secret?
F5 Version 9.4.3
Example iRule: (Mostly Working Except for Ribbon)
if { [string tolower [HTTP::path]] starts_with “/IT” } {
Rewrite host header value and select pool
HTTP::header replace Host teams2010.hbk.com
pool WSS_TeamsFarm_Pool
pool SP2010_Pool } }
hi Jharper,
Most of the time, issues with the ribbon, etc, are due to either incorrectly configured alternate access mappings, or compression. Have you looked at the traffic in HTTPwatch or some other tool to see what is coming back from the BIG-IP?
thanks
Mike
I’ve been using Fiddler2 and haven’t seen any errors. The problem is just occurring when using ProxyPass and other iRules that rewrite the URI. The Ribbon gets stuck in a loading state. I’ve configured the Alternate Access Mappings properly as far as I can tell.
Is it actually replacing the host header? You may need double quotes around the new host header you’re swapping in:
Also, when you use string tolower, the string you’re searching for should be in lower case-“/it” rather than “/IT”, for example.
I see the same behavior when using the ProxyPass iRule. It seems like it’s not redirecting something, but I can’t find anything in the logs. Have you be able to successfully redirect a subsite in SharePoint?
I have not tested that, or the ProxyPass iRule. Might be helpful to look at some packet captures from the servers you’re redirecting from/to, to see what the response is and if some request isn’t going to the right place.
This is working now. See this thread DevCentral - An F5 Technical Community
