redirect https to other https with condition
I have following iRules, its bind with virtual server
VS_HTTPS
i wants if someone tyle
https://devs.example.com
then it should redirect to
https://dev.example.com
i have tried following but it didn’t work.
in DNS dev and devs are both CNAME and they pointing to same F5 VIP
  if { ([HTTP::host] eq "dev.example.com") or ([HTTP::host] eq "devs.example.com")  } {
     devs -> dev
    HTTP::redirect https://dev.example.com[HTTP::uri]
    pool dev_pool
  } elseif { [HTTP::host] eq "qa.example.com" } {
    pool qa_pool
I am getting following error
$ curl -Ik https://devs.vivox.com
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
What is the error in curl command?
Redirect always respond with 302 status code and location header equal to redirect uri.
Satish, Did you try sending the traffic through web interface, and saw redirection ?
