If you’re not decrypting the SSL, you can’t view or interact with the HTTP, so no, you cannot issue an HTTP redirect. If you have to have the LTM to server connection encrypted, you could decrypt the client side connection with a client SSL profile and re-encrypt the server side with a server SSL profile. You would need to import the SSL cert and key to LTM for this. The cert would need to be valid for all fully qualified domains that resolve to the virtual server IP address.
You could need to import the SSL cert and key, create a client SSL profile which references the cert/key and then add the client SSL profile to the virtual server. The LTM config guide on AskF5.com describes this.
