I need to write an iRule that would route all traffic from a specific https pool to another https pool.
Thanks!
Thanks!
Can you elaborate on “route all traffic?”
Let’s assume traffic hits your HTTPS Virtual Server and that your Virtual Server has a default pool of servers listening on port 443. Where do you want the traffic to go after LTM sends it to the pool of servers listening on port 443?
I want it redirected to another pool. But let me explain some more please.
here is the setup: I have a pool of servers running Linux Apache web server which they act as Proxy servers for all incoming traffic (http or https). The Linux admin does not want to configure SSL/port 443 on the Apache server. So, is there a way I can route https traffic coming from outside through the F5 to another pool of servers that will accept https traffic or do I have to create a new VS using same IP for SSL?
Why not just terminate the SSL on the F5 and send over port 80 to Apache?
