redirect based on port
redirect based on port hi i need to create vip that on diffrent port redirect to diffrent server
for example : vip --> server a vip:8081 --> server 2
You dont even need an iRule for this. A virtual server on the LTM can be an IP/port combination. Simple create 2 or more virtual servers listening on the ports you need, and attach the required pool to each. The destination port with be ‘redirected.’
for example : vip --> server a vip:8081 --> server 2 or for example : vip --> server a vip:8082 --> server 3
create an individual VIP per port required. Same IP, different port, and allocate port in pool setup.
thats exactly ehat i did and it does not work when i add the port to vip it is going to nowhere
Apply the entry port to the VIP (I will assume standard http) , create the pool with the backend server(s), associate the port at the pool level, then it will go from HTTP > Whichever port is associated with pool.
