Redirect based on IP within X_FORWARDED_FOR
I am looking to find the way to redirect requests made to a virtual server to be redirected to a another Pool, based on the IP address within X_forwarded_for header.
Emilio
How about
   if { [HTTP::header "X-Forwarded-For"] == "192.168.5.100" }  {
     pool uat_pool
     pool main_pool
hope this helps
CB
That worked. I found another one which utilizes the data groups.
if { [HTTP::header exists “X-Forwarded-For”] } {
set xff [HTTP::header “X-Forwarded-For”]
xff may be in format of addr1,addr2,addr3
set addrs [split $xff “,”]
foreach addr $addrs {
if { [matchclass $::banned_addr_list equals $addr] } {
reject
Thank you,
Emilio
Hi Emilio,
An XFF header value (or multiple XFF headers) can be inserted manually by a malicious client. I don’t think it would be very bulletproof to depend on this header value to prevent known bad client IP addresses from accessing the VIP. It would be more ideal to filter at the device that sees the original client IP address as the source of the TCP packets.
Aaron
