rediecting site to different page but on same pool member..possible?
HI experts,
I am not sure whether it is possible or not. both sites are hosted on same pool member.
doesn’t normal HTTP::redirect work?
HTTP::redirect
Thanks Nitass for your comment. no normal redirect won’t work since redirect site hosted on same backend pool member. Yesterday I had successfully implemented.
  • when HTTP_REQUEST {
  • log local0. “Request: [HTTP::uri]”
  • if { [string tolower [HTTP::host]] equals “abc.com” && [HTTP::uri] equals “/default.aspx” } {
  • log local0. “sending request to error_aspx”
  • HTTP::redirect “https://abc.com/error.aspx”
  • } else {
  • log local0. “sending request to pool”
  • pool abc.com
Can’t you just rewrite the URI? using HTTP:uri?
Exactly where you want to change the URI is unclear, so this is a guess;
  log local0. "Request: [HTTP::uri]"
  if { [string tolower [HTTP::host]] equals "abc.com" && [HTTP::uri] equals "/default.aspx" } {
  log local0. "sending request to error_aspx"
  HTTP::uri "/error.aspx"
  log local0. "sending request to pool"
  pool abc.com
