I feel foolish for not knowing this but I have a really basic redirect question.
I have a server (maintained by a different team) that is listening for SSL connections on 7004 for a specific URI. For example:
10.5.x.x:7004/specific_example/
I want to setup a virtual server to listen for inbound requests on port 443 and then forward them to the server on the backside. I know how to write an irule to append the “/specific_example/” to the inbound request, but something isn’t working. I am doing this exact scenario with another server/team with the only difference being that I’m offloading SSL and not reencrypting on the backside as I was able to talk the other team into disabling SSL on their server. In this example the server needs to continue listening for SSL traffic so I have added the SSLserver profile, which is how I think you re-encrypt, but i have a feeling something isn’t translating b/c when I go to the virtual server i’m getting a 404, but when i go to the actual server I am able to get the web page to load.
Can you post the configuration for this virtual server and the iRule that you’re using? Via CLI -
tmsh list ltm virtual (vs-name)
You are correct - server-ssl profiles re-encrypt traffic to the pool member, and client-ssl profiles terminate SSL connections from the user at the F5. If you are receiving a 404 response, it appears as if IP/TCP traffic is properly flowing to/from the server and that SSL handshakes are occurring, the server just doesn’t have the URL being requested. If traffic wasn’t flowing or handshakes weren’t occurring, you would see timeouts or TCP resets, assuming the iRule isn’t configured to respond with a 404.
So, clientssl and serverssl will decrypt and then re-encrypt on the backend so you’re right on this. 404 is a page cannot be found so can you specifically check the full URL when you go via the VS (failing) and direct to the server (working). Might be a difference here?
strange, when I do the tmsh list ltm virtual i only show one virtual server (i have at least 30 configured). I am assuming this is b/c I used a template to create the virtual server…is there a way to show it if I used a template?
iRule is: when HTTP_REQUEST { Check if path is / if {[HTTP::path] eq “/”}{ Send 302 redirect to the new location HTTP::redirect https://[HTTP::host]/console-selfservice/ } }
Now i"m not getting a 404. I ran CURL from the CLI and I think I see the issue, but I’m not sure how to fix it. It looks like I’m getting a 302 from the server that is redirecting the virtual address to port 7004 (which doesn’t work b/c the virtual is listening on 443 not 7004 - the backside server is listening on 7004) < HTTP/1.1 302 Moved Temporarily < Cache-Control: no-cache < Connection: close < Date: Wed, 08 Oct 2014 19:36:56 GMT < Pragma: No-cache < Location: https://10.x.x.x:7004/console-selfservice/SelfService.do;jsessionid=6pFZJ1SYVqYB02RFhYct1znC9pmnvmKHM1ghZW7qy72Wcxh2yGD2!1168371165!1412797016546 < Content-Type: text/html < Expires: Thu, 01 Jan 1970 00:00:00 GMT < Set-Cookie: console-selfservice-jsessionid=6pFZJ1SYVqYB02RFhYct1znC9pmnvmKHM1ghZW7qy72Wcxh2yGD2!1168371165; path=/console-selfservice; secure; HttpOnly < X-Powered-By: Servlet/3.0 JSP/2.2 < Set-Cookie: BIGipServerMyToken_RSA.app~MyToken_RSA_pool=1866138890.23579.0000; path=/ is this something that needs to be changed on the server?
