RDP Seamless Configuration on an APM Remote Portal
Hi Guys,
have the following question. We build a remote Portal with the F5 APM and using RDP Sessions. All works fine but how can i configure a RDP Seamless Connection to start an application on a remote Server only via the RDP protocol. Is there a way to place it under the paramters? I have to give them a path and an executible file to start the application. We used it on a Juniper MAG and need it now on the F5 APM Remote Portal. Thanks in advance for your replies.
Kind regards Martin
